Robbie-87plz
Junior Boost-Head
- Feb 12, 2004
You guys notice a drop in voltage when under boost conditions?
..to about 12.2 or so...and I'm getting false knock under boost...10 lbs with eric's chip and maybe 1 or 2 degrees of knock showing on the SM. Thanks for the continued help...
...I keep dropping voltage when the car is under boost...causing the knock...could it be...the alternator is bad? I replaced the belt, so I don't think it's the belt that's slipping...
Possibility that Checkers could have sold me a bad alternator?
What's your fuel pressure & chip timing at? Can you take some timing out of the chip? And are you running Alky?Originally posted by Robbie-87plz
