Valve covers for M&A Heads
Need valve covers, center bolt, M&A heads.
They also need to clear jessel style rockers.
Thank you
The ones I have are the stock M&A. Not sure about the Jessel set up. Call Mike at Full throttle . He'll know. I've also got a set of RJC valve cover spacers that'll give you extra height.
M&A valve covers do work with roller rockers, but RJC spacers are not an option.
Try TA Performance as they have lots of M&A parts - 480-922-6807
Sent from my HTCONE using Tapatalk
I have m&a heads on my 109 motor so I feel your pain. What happened to the original valve covers? I'm assuming you obviously have m&a heads correct? Well you are probably not going to find a set at least not very easily. But here's an idea. Take a look at the guide pins on the valve cover rails on head. I matched them up and I'm pretty sure if you drill and tap them you could use any stock style valve cover and just bolt them on. May be an option for you. Hope it helps. Joel
