Everyone Points To The Pontiac Tta. They Came Out In 1989. I Think Only 1500 Were Made. I Also Think That Gm (delco) Did Not Have The Powermaster Still In Production In 1989. The G.n.'s Ceased Production In 1987. They Sold The P/m To Raybestos. So, For 2 Years There Was No Production Need For The P/m, And No Other Cars Used Them. Buick Never Put A Vacuum Booster On Their Turbocharged Cars. Only The Standard Regals. Buick (gm) Was Concerned About Turbo Boost Blowing Off The Vacuum Hose, Or Blowing Into The Check Valve Into The Booster. This Would Explode The Vac Booster With 20lbs Of Air Pressure. Big Liabilities. The Only Way A Turbo Engine Can Pull Vacuum Is When The Throttle Shuts, At High Engine Speed. With The Overdrives, There Is No Decelerating High Engine Speed. The Engine Basically Freewheels, Vacuum Wise. If, You Wanted To Downshift Everytime You Wish To Stop, Then You May Have Vacuum. So, G.m. Installed A Vacuum Block To Prevent Turbo Pressure From Entering The Vacuum Booster. G.m. May Have Also Ground The Cam Differently On The Tta To Increase Vacuum. The Less Duration Of Valve Opening, The Higher The Vacuum. My Point With The Hydroboost Is It Does Not Care What Cam Shaft You Run. It Does Not Care How Much Boost Your Turbo Puts Out. It Doesn't Care How Much Horepower You Have, It Just Delivers The 2000pis To The Calipers, If You Want It.
