The vacuum pump has been used for years, but the good one that was made by A C Delco was obsoleted a few years ago. It had the relay and on-off sensors built in. Most aftermarket pumps do not have the sensor switch, and run continuously. This means they last about 6 months before burning up. They also cost $350.00 to $450.00 plus install. Even with the vac pump, you end up with the equivalent of a stock Regal power brake. This is still too weak for a serious performer such as the GN. We have been in the power brake business for 55 years, and actually installed every variation of these systems. We even installed systems for the handicap vans. The hydroboost beats them all. Read "HYDROBOOST VS VACUUM VS POWERMASTER"
