TurboTA3.8
You wont keep up the pace
- May 24, 2001
TTA engine Fuel lines $60
tta oil cooler setup $80
tta/gn cam sensor $45
tta/gn 200 mile coil pack and module setup $100
tta motor mounts both sides right left engine and frame 1 frame mount need a small repair anyone with a drill and a welder can fix in 15min $150
a/c eliminator idler pulley $60
PTE polished 75mm doghouse and t body with ported lower intake and rjc plate to match $350 SOLD SOLD SOLD
JW wheel flex plate $185
stage 2 balancer hub with crank trigger built in works with stock pulley dont know brand $175
TTA transmission oem x member complete with torque arm mount and trans mount $135 sale pending
tta random technology torque arm $200
aeromotive pro series fuel pump with filter $550
buick engine assy bracket $50
paxton automotive afpr $75
stock tta fuel rail $20
fmic for tta needs a new discharge pipe made for a different then tta stock turbo easy fix at muffler shop to make a ic pipe $800
lakewood rear lca for tta $50
tta oem trans line one line has a small dent near rad atachment point but does not obstruct flow $75
tta radator and fans $150
tta oem full working dash cluster comple $600
tta oem complete engine wiring harness with relays $400
alternator $100
alt bracket with tensioner $40
billet alum vac block $40
billet alum 45 deg iac relocator $40
vac lines $30
throttle bracket $10
crank sensor with bracket $25
coil back bracket $25
oil filter housing buick $25
timming cover fuel pump block off plate $10
water pump with pulley $40
crank pulley stock $50
buick stage 2 off center block, commetic head gaskets , m&a race ported heads with stainless manley valves 1.94 intake 1.60 exhaust ,ngk fr5 spark plugs ,4.005 bore je racing forged pistons ,je racing moly piston rings ,corillo h-beam rods ,buick motorsports 3.58 stroke crank ,comp cam solid roller .572 intake lift .572 exhaust lift duration at .050 230 deg intake 230 deg exhaust lobe seperaton 112 ,arp head studs arp main studs , stage 2 4.1 block ,four bolt mains, roller rockers ,alum valvecovers
$9000.00
just rebuilt ITS T-80 turbo 3 passes sence rebuild has a x trim turbine duel ball bearing option and polished housing .96a/r exhaust housing $1800
I'm selling my FAST "aka"speed pro bank to bank system. It is complete for the 87 Buick GN or 89 tta. It includes WB 02, harness, ECU, and interface cable . It is ready to install.
$1400.00 shipped
2004R TRANSMISSION
* HARDENED PUMP STATOR * 10 VANE HI VOLUME PUMP KIT PTS SUPER PUMP ALL GM PARTS * CHROME-MOLY PUMP RINGS * .570 TV BOOST VALVE * .400 INT BOOST VALVE PTS * BILLET SERVO * RAYBESTOS "BLUE PLATE" DIRECT CLUTCHES * ALTO 2 3/8 inch H/D BAND * 300m BAND ANCHOR * ROLLER BEARING CENTER SUPPORT * TEFLON C/S RINGS * PTS "BAT BRAKE" Transbrake * BILLET INPUT SHAFT * BILLET CHROME MOLY OD PLANETARY,* BILLET INTERMEDIATE FORWARD CLUTCH DRUM SHAFT * TEFLON PUMP & DIRECT DRUM BUSHING * PTS "BOTTOM FEEDER" FILTER/SUMP SYSTEM * RAYBESTOS "HIGH STATIC" LOW REVERSE CLUTCHES * PAN DRAIN PLUG * NEW TCC SOLENOID (If lock up) * VALVE BODY & GOVERNOR MODIFICATIONS * HARDENED H/D DRIVE SHELL * ROLLER BEARING L/R CENTER SUPPORT * ROLLER BEARING PARK GEAR SUPPORT * ALUMINUM PAN * PRO TORQUE 3800 STALL CONVERTER RATED FOR 1000HP, TRANS IS FRESH ONLY 3 LOW 10 SEC PASSES ON IT WORKS FLAWLESSLY 1.39 60 FOOT
$2800.00 OBO
FREE INSTALLATION AVAILABLE FOR LOCAL SALE
alternator $100
vac lines $30
$9000.00
$1400.00 shipped
2004R TRANSMISSION
$2800.00 OBO
