Thought I would post some pictures of my GN build and the combo as it comes together over the next month. The car will see cruise night action, shows (Lookout PhillyTurboSix!!!), and strip duty with 9’s in mind. I’ll be slowly stepping into the combo/tuning with reliability in mind (If there is such a thing!). The combo is a little radical for some but it’s my vision of an all-out street car.
First, big thanks to Otto from Otto's performance who is doing most of the wrenching on the car (Motor/Suspension/Trans/Rear/Gauges/XFI/Tuning/Counseling...you name it). I can’t say enough about his service, work ethic, and overall what a great guy to do business with. I would highly recommend him for any job – mild to wild.
Thanks to Russ Merritt who is handling the motor machining, assembly, and head work. Russ worked my factory 109 - 5 over and did an excellent job machining my 109 block for the RJC girdle. He also ported my GN1s.
Stroker parts and rotating assembly are from Dan at DLS who spent a lot of time on the phone with me and truly cared about my satisfaction with his parts and service over the past 1.5 months. From his competitive prices to the depth of knowledge on the 109 what a great vendor to deal with.
Also – Big thanks to my wife Allyson who has supported me throughout the process!
Car – 3rd Owner T-tops w/ 39K original miles purchased from Bruce in Michigan in October of 08. Just repainted by Shawn Smith Auto Body in Bensalem PA. Car previously had an 80s ground effects kit which was removed with all bolt holes welded and filled by Shawn.
- Glass Bumpers/Hartline Glass Hood/79 GP Alum. Core Support
- JW Racing Fab 6 Chrome Moly Roll Bar w/ Swingouts
- RCI 6 point harness
- All original full interior
- No AC/Heat
- ~400 lbs of weight reduction including roll bar
- Autometer Carbon Fiber Gauges / Innovative WB/ Caspers Knock
Engine
- RJC Girdled / DLS 3.625 Wide Journal Crank / Rods / CP Pistons
- Russ Merritt Ported GN1s & GM Timing Cover
- DLS Custom grind roller cam w/ LSX dual valve springs
- Scorpion Rockers 1.65
- BHJ Balancer / JW Flywheel
- RJC Pullies / Deep Sump Oil Pan
- Champion Ported & Polished Lower w/ Precision Plenum & 70MM T Body
- XFI by OTTO
Turbo/Exhaust/Intercooler/Fuel
- PTE Billet Wheel BB 6768HPQ 4 Bolt -Air Cooled
- TA Performance 4 Bolt Headers
- JW Racing Fab custom 3.5 Stainless DP & Cold Air Pipe
- Dynatech Split flow 3 inch race mufflers
- Precision external gate
- RJC Megacooler
- Reds Double Pumper / Stock Lines / Precision balanced 80s / Razors Dual Alky
Suspension/Brakes/Rear/Wheels/Tires
- Front – TRZ Upper/Lower Control Arms, Wilwood 1st gen Fbody brakes, Fbody spindles, TRZ billet steering arms & Bump Steer kit, Strange singles
- Flaming River 1500Q custom manual box set-up (THANKS BILLY T!!!)
- Moser Axles / Aluminum Drums / big studs
- TA Girdle
- Metco lower and adjustable upper control arms
- HR Parts Sway Bar / Motor Mounts / Frame Braces
- RJC Engine Brace
- Weld Magnum RTIIIs w/ Black Annodized Centers (15x5 & 15x10) on Drag Radials
Trans
- Otto built full billet 200-R4
- CK Performance Billet parts / Clutches
- PTS Extreme Deep Trans Pan
- Dusty’s PTC Converter
- Dynatech Aluminum Driveshaft w/ TNT Fab loop
I will continue to update the thread as we progress with more pictures. Hope to have the car ready for Etown EFI Race # 1 in early April.
Bill
bszablewski@yahoo.com
- No AC/Heat
Engine
- XFI by OTTO
- RJC Megacooler
- TA Girdle
- RJC Engine Brace
Trans
Bill
