boostjunkie
NEED MORE BOOST
- May 27, 2001
Guys any input on this will help . have a Typhoon that is running real rough put the scanner on and i am getting a code 43 ESC falure, 31 wastegate overboost ,33 Map sensor high, 53 high voltage, also the knock sensor is reading 4 deg of knock. it runs just like a GN with a bad ECM or chip . the cap rotor plugs and wires were replaced less than a year ago also replaced all broken or bad vac lines not to long ago. just hate to buy parts i do not need . thanks shawn
