Went out to the garage the other evening and to my surprise I heard a whirring sound coming from my GN. Seems that for no apparent reason the power antenna motor was working. I was lucky from the perspective that this didn't happen elsewhere to totally drain the battery etc, yet what is the explanation? Did the relay go bad? I assume the dreaded nylon cable is now toast too. Therefore the second question. Does the cable from the antenna to the radio also fit the fixed mast antenna from those cars or does that cable need replacing if I convert from the power antenna to the fixed antenna? Thanks for the help.
Dean
Dean
