This is a continuation of the following thread:
http://www.turbobuick.com/forums/general-turbo-buick-tech/326778-turn-signal-issues.html
I started a new one because I think Ive narrowed down the problem to either the headlight/dimmer/or twilight sentinel switches.
Here is whats going on:
When I use the left turn signal all of the lights flash like hazards and the interior lights/gauges flash with the bilnker.
What I have done so far:
Replaced every bulb in the car with correct type, replaced front driver side corner light socket (for some reason this bulb doesnt flash with the rest of them, it flashes, but very dimly), checked and cleaned all grounds (fenders & trunk).
I also tried a new turn signal switch in the column and no go.
I also pulled the switches on the dash and noticed that when reinstalling the twilight sentinel dimmer the headlights stay on no matter what until I unplug it. Also, the amplifier behind the glove box clicks loudly when putting the switch in and out.
Is all of this related to the twilight sentinel, maybe the switch itself? Any help is really appreciated, this is turning into a huge pain.
