Any suggestion on what size turbo would be a good upgrade with stock convertor and 36 lb injectors?
Personally, I would spend the money on a good recording type scantool/WB, and upgrade the fuel pump with hotwire.I don't want anything crazy just for the street. I have put on/in 91 chip, which i will up grade, adj. Fuel pump, pulley kit, bigger maf, new dual exhaust with cat removed, (want headers), 87 coil conversion,adj. Wastegate. I just try to add something every month or two so i can still enjoy driving. Still fun blowing off those 4 bangers.
You can get one from one of te vendors on this board.Forgot who would you recommend getting the ta33 from?
I got the hot wire kit , but haven't installed it was waiting to change out pump, should i wait?
Is the alky injection a complicated job, i have worked on cars since i was 15.
Not really, notice when its really hot and i don't add my octane booster mix, toulene-mineral spirts and trans fluid.
Yes, the gas down here sucks , always use 93 octane-chevron, they buy from independent guys. No amoco or sunoco here. It just happens just for a second and goes away,
boost right at 15,
Factory
