freakazoid
- May 21, 2006
i am having problems building boost over 20 lbs. the turbo gauge displays up to 40lbs of boost but the needle will only go up to 20 lbs but will not pass it. i have changed the waste gate to one that is good up to 30 lbs. i have a te-45a turbo, a front mount intercooler, 76 mm throtle body, roller rocker cam, ported iron heads, terry downpipe, alky system, rj power plate, 50 lbs injector. 3 inch mass air flow , cold air kit... the car runs perfect, not popping or miss fire...
i have checked the puck (sanded both side) to make sure that it is making good contact. it does not appear to have any leaks.. where can i double check? or change to achive more boost???
ANY ADVISE????
ANY ADVISE????
