Firing Direction
Maybe I read the circuit wrong, I'm a mechanical engineer/metallurgist, not an EE. However, the Buick shop manual says, and I quote; "Because of the direction of current flow in the primary winding and thus in the secondary winding, one plug will fire from the center electrode to the side electrode, whle the otehr fire from side electrode to center electrode." Only one end of the primary goes to ground, so current flows in one direction. Each primary coil has a blue lead, which is "hot", and striped lead, which is ground. Looks to me like current flows from hot, to ground, builds magnetic field, primary circuit opens, field collapses, secondary builds voltage in opposite direction, plug fires. But I can't see how it would fire one direction on one stroke, the other direction on the other stroke. Especially since there is no "TDC on compression" signal. The injectors fire on compression, but the ignition fires the same way on compression and at TDC on exhaust. At least that's what I think.
