Just installed a ck 200r4 shift kit and now no gears will engage. Shifter goes thru all gears fine sitting still but no engagement. I can hear the manual lever on the paw moving . Trans was fine before I started . I removed trans pan and noticed pump pressure valve assembly was stuck..no spring movement at all. Took out and put old 5 peace kit back in ..plenty of spring tention...felt good. Same problem. I don't think pump is giving any line pressure . Fluid stays cold after warm up. Fluid level is good. Let car warm up for 40 mins and worked shifter thru all gears several times. Thanks in advance
