There are five feeders that attach to three fuse links (shared links on two pairs). Of that, only one feeder powers the entire vehicle electrical system minus the engine. The second feeder powers the engine electrical system. Then one feeder runs the coolant fans, one runs the blower fan, and one runs the power brakes and high speed fan system.
Voltage drops will occur at the ignition switch, but most commonly, at the C100 bulkhead that feeds the dash fuse panel.
Best choice is to unscrew the single bolt that holds the bulkhead to the firewall, pull the connector out, and soak it in paint thinner to remove the tar from the terminals. Clean it with a brush, then inspect it thoroughly.
My bet is that you'd find corrosion on some of the terminals. It will look like a white or green powdery substance on the surface. If so, it's generally the cause of your voltage drop. There is no real way to repair this; you need to replace the terminals on both sides of the connector. Then repack it with white lithium grease and re-assemble.
I'm sugar-coating it...this is a PITA project, but it's the only way to really fix the problem.
