L Lhorn Member Joined Feb 28, 2003 Aug 29, 2006 #1 Anyone know how much you torque the three bolts that hold the rocker arm shafts? Thanks
T turbocody GOT BOOST! Joined Jan 15, 2003 Aug 29, 2006 #2 i think it's 15ft lbs. i just snug them tight with my 3/8 socket wrench
Q QUIP'6' Brian Roman Joined Nov 26, 2003 Aug 29, 2006 #4 http://www.gnttype.org./techarea/misc/torque.html its 25 ft pounds
L Lhorn Member Joined Feb 28, 2003 Aug 29, 2006 #5 Thanks for the replies. Didn't even know that table was on GNTTYPE.
4 49-blues Active Member Joined May 30, 2001 Aug 30, 2006 #6 25 lbs iron heads, 20 lbs gn-1 aluminum heads.
U UNGN Can't Re- Member Joined May 24, 2001 Aug 30, 2006 #7 I would go to 23 lbft and call them good. 25 is at the upper end of what they will take. The spec for an 8.8 8mm bolt is only 17 lbft and for a 10.9 8mm bolt is only 24 lbft. No way those bolts are stonger than a 10.9.
T tom h Active Member Joined Sep 1, 2001 Aug 30, 2006 #8 the original buick service manual specifies 25 ft-lb, consistent with most of the previous answers.
B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Aug 30, 2006 #9 UNGN said: I would go to 23 lbft and call them good. 25 is at the upper end of what they will take. The spec for an 8.8 8mm bolt is only 17 lbft and for a 10.9 8mm bolt is only 24 lbft. No way those bolts are stonger than a 10.9. Click to expand... I think the threads are 5/16-18. I use grade 8's and they yield a good bit when torqed down
M m233roller Banned Joined Jan 25, 2002 Aug 30, 2006 #10 I go 24-25 lbs. and alittle red loc tight on the threads. Never had any problem.
