TinMan GNX Brace Install question
Danster
Senior Member
I am in process of installing the GNX brace and per the instructions, remove the rear wheels to acces the 4 lower brace bolts which attach the body brace to the floor plan.
What bolts are they referring to? The two rear Body Bushings bolts on each side? One behind the wheel and the one in front?
TIA!
Dannyo
I think what they are reffering to is gaining access to the bolts you are going to install to hold the brace in.
Weld it in. Tig it and be done. Drilling all those holes and bolting it in...never seemed like a good idea to me. I had it tig welded in and it is well worth it.
Master of the obvious here but make sure to disconnect the battery before welding...
Sent from my SPH-L900 using Tapatalk
