Third brake light not working!!!
stephaned
Hi everybody,
«as the title says...
Bulb is ok, stop hazard fuse ok and wire is connected and seems ok. Any other route I should follow to solve the problem.
thanks a lot
Check for power at the switch that is operated directly off the brake pedal under the dash just behind the A/C vent, if there is not power-backtrack circuit, powered-check switch, check continuity between switch and bulb positve, couldn't hurt to check for ground at the bulb too.
Good Luck
Pm me with how you make out
