THDP stuck puck
robh
I have a 3" SS Terry Houston down pipe that I bought in 2000. I don't drive the car much and haven't been WOT in 5 years. I recently poured some C16 in and tried to make some passes. I was seeing 30+psi until I let off. I found the waste gate puck completely stuck. Any thoughts on how to fix it or prevent it from happening again?
TIA
Rob
I would replace the wastegate puck assembly. RJC sells a quality replacement. Cut the old one out, remove and install the new sleeve,tig weld the new flapper on. Done. Problem solved.
Thanks. I will order the parts from RJC and replace the assembly. I'm just amazed that it happened. Thank god for c16..
