Now you are obviously a way sharper tranny guy than me so school me if I'm wrong here.
Increasing clutch pack clearances does not increase apply area.
You have a set amount of apply area on any given piston that is pretty hard to change due to piston shape, drum size, etc..
Basically if it is 15 square inches of surface apply area, that's all it is and that's about all you can do.... Without fabricating a larger piston/ drum assembly...
If you leave more clutch pack clearance you are basically leaving more travel for the piston. But a clutch pack is a certain thickness,
you could thin it by running thinner steels, but still, it is going to be a given thickness. So more clearance between the piston and the clutches is just that,
once the piston gets to and compresses the clutches, it can't go anymore...
So you really haven't added any fluid capacity or apply area, just more piston travel?
If you machine the piston down, leave clearances loose, thin the steels, you get more fluid behind the piston but all the force would be applied to the drum walls and not the apply piston anyway. right?
100 psi of preesure on 15 square inches of apply area is 1500 pounds of pressure, whether there is 10 oz of fluid behind it or 10 gallons. That's my understanding of hydraulics. Maybe I do need to go read Pascals Law though.
If you have more fluid behind the piston, it would just be exerting more pressure on the drum, because the area of the drum wall would be increased.
And if you theory is correct, don't you run the risk of overtraveling the piston and busting a lip seal?
I've done this air checking drums with no clutches in them....
I do agree that a normal clutch pack clearance may give a better shift timing than one that's built too tight, less chance of harsh engagements when changing from neutral to a given gear,etc..
I'm here to learn so just trying to figure out what I may be overlooking, or misunderstanding.
Jake
