Hi everybody ,my TH 400 started to act weird , MVB with trans brake , have very slow reverse engagement or no reverse at times at all , this will happen with trans shifted into reverse or in neutral with trans brake switch applied ,same thing !
In the morning when fluid is cold I may get slow reverse engagement bit it will always work but....... after it gets hot I usually have NO REVERSE , the only way to get it to go in reverse is to rev it up quite a bit and may have to continue to do this since it will not stay engaged , any ideas ?
...............fluid and filter has been changed with additive to clean up valve body , nothing major found in the trans pan at that time .......
Greg
Greg
