Both are going to produce the same performance and spool relatively the same on a stock cammed/headed turbo regal. The only advantage to a te 60 is its easier to get a higher hp turbo just swapping the turbine and having the housing cut for it. It quickly becomes a small shaft 60-1 aka TE62. Garretts names for the turbines and compressors are as follows: TE44-t04e 60 trim compressor/stage 3 high flow turbine, TE60-t04e 60-1 (small shaft) compressor, stage 3 high flow turbine, and the TE62 is a 60-1 compressor and 76 P trim turbine. There is also a 60-1 compressor/69 trim turbine aka TE61 or PT54. Even the GT35R compressor can be had easily with a t04e style turbo these days. All the compressor and turbines are very interchangeable in the t04e series. If the engine has heads and cam a larger compressor and higher flowing turbine will open up the mass flow potential a lot.
