Please help.
I just bought a TA49 and a 3" THDP. After installing (along with other mods - see below) I now get very bad over boosting. Initially, I had over 25 lbs of Boost and excessive KR. I have adjusted my Actuator Rod out all of the way and that has helped. My chip is a 17lbs Joe Lubrant (93 Oct). As of last night's testing, the lowest boost I can get is about 16 lbs, which seem ok (Only 2 - 4 degrees of KR max)
My Puck is 1 3/8" (Seems large - From my 3" THDP)
My hole is only 15/16" (Seems too small to me- TA49)
Should I have had the WG hole increased to 1" or more ???
What is the correct size for my mods???
TA49, Mark Jackson "Stretch" IC, Blue Tops, Adjust. Fuel Reg (46 Lbs), 3.5" MAF w/ Translator Plus, Power Plate, Big Mouth Ram-Air, Kenne Bell Plenum, 3" THDP, 3" Cat, Hooker 2 1/2" Exh, DynoMax Ultra Flow SS Mufflers, Kirban Valve Spring Upgrade kit, 307 Walbro FP, Joe Lubrant & Extender chip.
Brandon
Brandon
