I had the fuel at 10.8-11.0 on one pass and it was knocking at the top of 2nd, on the shift and into 3rd. I have the log, but think it was 6-9*.
What's your delta?
Dumping more meth to cover up the iat issue is NOT the solution. Turn the boost down. If that alky pump for one reason or another doesn't spray (no alky in tank,leaks,pump quits..) you are fooked!!! DO NOT TUNE LIKE THAT GUYS. Tune safe!
You want the timing high down low as you are building cylinder pressures , then drop off up top when most load is on the motor. jmo, stock computer ? See what the car likes , 22*/18* 21* up top is too much.
Your air fuel ratio is too rich. Your a/f depends on the amount of boost you are running. 20# boost 11.4/11.5 is tits. 30# 10.5-10.7 ...
Get a new converter Turbo Keith. Check your iat's . Post your delta.
I did what everyone said , Call Dusty , PTC is the way to go . Dusty said the 10 " LU is what he said will work for the 49 and will work if I go to a 6262I think you should try a different converter to maximize the stock motor and 49.
On my 10 sec 49 combo with the stock cam i ran 2 m10s and 42lb injectors.30 psi with timing in the 26 degree range and even went higher.these are real results.still waiting on a response from you regarding your real world 60ft results.Dumping more meth to cover up the iat issue is NOT the solution.
Really you can say that regarding every mechanical piece in the car If it quitsI have seen more fuel pumps straight up quit and no alky pump failures they drop off pressure eventually and if your looking at a gauge you can see it.If that alky pump for one reason or another doesn't spray (no alky in tank,leaks,pump quits..) you are fooked!!! DO NOT TUNE LIKE THAT GUYS. Tune safe!
He said when he leans it down it knocks. See you're just looking at numbers and you're actually not paying attention to the testing that he is done,each car is different.Your air fuel ratio is too rich
It's building heat as it's going down the track. Richening it up or adding more meth to cool it down is the only way to keep it together.had the fuel at 10.8-11.0 on one pass and it was knocking at the top of 2nd, on the shift and into 3rd. I have the log, but think it was 6-9*. Turned the meth and added a number to a few cells and it went down with no knock.
I love the 9.5 non lock ptc.working is different from maximizing. We tested a lot of different things to make the 49 combos run. On the lock up stuff we found that making the converter very loose and then doing a manual lock up was the fastest way.i mean real loose we were 3200 to 3500,but if you didn't lock it down it would lay over on the big end.locking it down was 5mph on a 49 and stock motor.looking at the slips you can see where things are soft or could be improved. What I'm talking about was done a very long time ago and I haven't ran any of the new converter teck on a stock combo would a 49. We were dealing with D5s orange stripes, red stripes ,Vig multi disk lock ups,a.c. 9 non lock, and pro torque made a killer 10.5 with a lock up clutch that could be used at wot.but in the end loose down low and coupling up top is the answer,the 49 when setup right hits real hard and has the ability to nail down the 1st half of the track real good mine would run high 6s in the 1/8 and fastest 1/4 mph was 125.I did what everyone said , Call Dusty , PTC is the way to go . Dusty said the 10 " LU is what he said will work for the 49 and will work if I go to a 6262
I wouldn’t. I’ve been able to get the MFS 6262 all in on a stock exhaust housing.
I was locking in 3rd gear,tried it all over the place but it would et better with mid 3rd gear lock 25mph back half at 3732lbs on its worst day 23.i hammered mine on the street a lot got a lot of passes and good miles on it but the clutch was very worn I upgraded to Kevlar single but moved to a ptc 9.5 for a combo change.overall I think it's tough on the clutch but it worksWhere were you locking the tcc on the 49? We tried a lot to gain mph out the back last season, but only could gain 20mph. I tore into the engine and realized the exhaust lobe on cylinder 3 had a whopping 0.135” lift. How taxing is it on the clutches to lock it up like that? We are at 22mph out the back last week going 89mph in the 1/8 and 111mph at the 1/4, unlocked tcc. I pulled a degree out up top and we are going to try and get it in the mid 10’s afr around 25psi this Friday.
the 9.5 nL th400 converter from dusty that was used for low 9s on a gn1 headed 234cube 71hpqbb motor works better than expected on a stock engine-untouched heads stock cam -pistons -timing set and stock turbo ..so far 118.9 11.20 (1.51 60ft) all at under 4850rpm
This is not good advice. I would not follow it. All cars have different likes and things that work for them. Their A/F ratio is rich for some as he said knocks when leaner. May want to look at what plug they have in. Fuel pressue and amount of alky going in as well. We dont have enough info to say the things you said. Not lower the boost. The Timing is average for that boost and Ive ran more. Some use less.
Didn't see before. If it's knocking you always turn down the boost and check fuel trim and logs. Fuel trims first first. Fuel pressure 41-43 vac off at idle. Alky gain 5 /5.5 is a good start.
This isn't 1980 anymore . Most chip makers stay under 20* @ wot anymore. Never had an issue. Hi timing equals High cylinder pressures
Mr Spool , never had a alky pump fail? One of the best turbo gurus just posted on this thread had a pump fail. Mine failed...
This isn't 1980 anymore . Most chip makers stay under 20* @ wot anymore, or no higher than 18* up top. Never had an issue. Hi timing equals High cylinder pressures
Mr Spool , never had a alky pump fail? One of the best turbo buick gurus just posted on this thread had a pump fail. Mine failed...
