Yes that's exactly it..Might be talking about Bisons mfs 59 mm (11 blade compressor)...paired up with the taller turbine 65.
65 turbine , this turbo works really well with the bottle neck stock heads, it spools like a 49 with the power of a 62#/min turbo, I really like the mis-match of wheels with shitty heads...TA cover, billet wheel, garrett .63 id bet this turbo is 10.70s on a good air motor.You may have a winner there with a billet 60 on a stock motor what size ex wheel are we talking about?
That thing looks pretty cool.i love the 65 turbine wheel but on stock heads and low compression I would never think it would spool great I usually would go for the smallest turbine wheel I could get away with and run a tighter converter to take down the slip up top if running the 1/4,the 1/8 is a different story.i have used a 65 turbine wheel over 80lb/min on a built motor.i haven't really played with the stock stuff for max performance in a long time though and not familiar with a billet 60.i remember cast 60-1 with various turbine wheels and the the hot was a performance killer on the stock stuff if you went to big.that garret.63 is probably vital on that combo.how fast are you seeing the boost curve? At what rpm do you see max boost pressure at off the footbrake?and how many seconds from initial boost?if you don't mind me asking.65 turbine , this turbo works really well with the bottle neck stock heads, it spools like a 49 with the power of a 62#/min turbo, I really like the mis-match of wheels with shitty heads...TA cover, billet wheel, garrett .63 id bet this turbo is 10.70s on a good air motor.
49 used to surge it butt off never hurt anything though.surging seems to be part of the game when the ve sucks and you manage to get smaller turbos to spool fastI will tell you I had the same turbo from Bison and I said the SAME THING! Thought it hit harder than 6262,6266,T64,T66. Delta was on the high side were I was running it.
Didn't care for the surge at different throttle angles... That's what happens with hybrid turbos... It works great at WOT .
Would this be surging on my fast graph?49 used to surge it butt off never hurt anything though.surging seems to be part of the game when the ve sucks and you manage to get smaller turbos to spool fast
You have heads and cam.im referring to a stock motor.you will know when you have surge it's very noticeable and mainly when the turn spools fast and your really low on the throttle.just put your foot into it moreWould this be surging on my fast graph?![]()
Im running it with a 0-pump 5 disc vigilante now, use to run it with a edge racing 9.5 and it seemed to couple better down low with that, hits 26psi in less then half a second, engine was done at 5100 rpms and didn't gain anymore power after 27psi , when I had the 6262 on the same stock motor it felt like it had more torque mid range but it spooled slower and the car was considerably slower maybe .5 tenths.... I keep my wagon with an all stock long block for testing purposes then I go to my other cars with the built motors to see the differences..That thing looks pretty cool.i love the 65 turbine wheel but on stock heads and low compression I would never think it would spool great I usually would go for the smallest turbine wheel I could get away with and run a tighter converter to take down the slip up top if running the 1/4,the 1/8 is a different story.i have used a 65 turbine wheel over 80lb/min on a built motor.i haven't really played with the stock stuff for max performance in a long time though and not familiar with a billet 60.i remember cast 60-1 with various turbine wheels and the the hot was a performance killer on the stock stuff if you went to big.that garret.63 is probably vital on that combo.how fast are you seeing the boost curve? At what rpm do you see max boost pressure at off the footbrake?and how many seconds from initial boost?if you don't mind me asking.
Interesting post.sounds like the rpm window on the 62/62 was missed which is common on the stock stuff,the interesting thing to me is how the 60 billet even though bigger on the turbine side stayed in the rpm range before fall off.thats where having heads would really help even a stock cam car,I noticed it allows for more air in a narrow rpm window.Im running it with a 0-pump 5 disc vigilante now, use to run it with a edge racing 9.5 and it seemed to couple better down low with that, hits 26psi in less then half a second, engine was done at 5100 rpms and didn't gain anymore power after 27psi , when I had the 6262 on the same stock motor it felt like it had more torque mid range but it spooled slower and the car was considerably slower maybe .5 tenths.... I keep my wagon with an all stock long block for testing purposes then I go to my other cars with the built motors to see the differences..
I have noticed surging at mid throttle , I just figured it was just part of it . I may be showing my ignoranceYou have heads and cam.im referring to a stock motor.you will know when you have surge it's very noticeable and mainly when the turn spools fast and your really low on the throttle.just put your foot into it more![]()
Noticing something is far from ignorance that's called experienceI have noticed surging at mid throttle , I just figured it was just part of it . I may be showing my ignorance
Compressor surge is not ideal.lol It's always a good idea to look at a compressor map if it's available. Anytime the pressure ratio and airflow meet to the left of the surge line, the turbo is said to be operating in surge.
Remember that's the old cast 59mm not Bisons
Turbo Keith, have you tracked the car? What does it run?
Informative thread.... a lot to take in Keith.There are plenty of wheels available now that replace the cast wheels and drop right in that will work better at higher pressure ratios with a slight drop off in max flow. The real solution is to get a good set of heads on the engine and put in a converter that can handle it. Increasing the engines mass efficiency helps a lot because the drive pressure can be lower to move the same amount or more air with the big restriction.
