AN/GSC-52 Active Member Joined Dec 6, 2009 Jun 27, 2017 #1 Will a Olds Cutlass 85 t top fit a 86 GN? Lost pass side on a short test hit. I put some corrosion inhibitor in the front channel and forgot to lock it, ugh.
M mr84ss Active Member Joined Aug 20, 2008 Jun 27, 2017 #2 It should, they're both Gbodies. Just switch the trim over if needed Sent from my LGMS631 using Tapatalk
AN/GSC-52 Active Member Joined Dec 6, 2009 Jun 27, 2017 #3 thanks, Ill take parts and match them up. Will add new step to preflight checklist.
