SX fuel pump, filters, and braided hoses.
Wknight13
SX fuel pump w/ pre and post filters. Also 5' and 3' braided hose (3/4"). Works fine, just went back to internal pump setup for street. Also have tank retro'd for this hookup ($75) . Came off my 87 GN. $350 for pump, filter, and hoses.
SX fuel pump model 18201 Summit Racing
SX fuel filter model 41002 Summit Racing
JEGS fuel filter (black one)
Will sell modified G-body tank for $75
Fitting sizes are combo of AN 6 and 8
Update after more intense research of items and realizing I did the right thing going back to in tank. My car wouldn't handle this setup, don't know what the last guy was thinking. But this set up is a beast...Here is more info on the parts:
18201 EFI & Carbureted In-Line Electric Fuel Pump
Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI. Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI. Flow-through design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle. -10 AN inlet/outlet fittings for easy installation. For use with gasoline or alcohol fuel systems. Passes UL standards for Coast Guard approval for use in marine applications. Fully re-buildable.
41002 EFI & Carbureted Slim-Line Fuel Filter
-10 AN Inlet/Outlet Ports
Calibrated for all EFI and carbureted engines up to 2000 HP
Compact flow-thru filter design and enlarged ports will literally flow the maximum of whatever a -10 AN line can handle
Virtually no pressure drop [less than .15 PSI pressure drop at 200 GPH]
Easily connects before and/or after the SX Performance™ In-Line Electric Fuel Pumps
Quickly and easily install and remove aerospace fuel filter element
Compatible with gasoline and methanol.
JEGS Performance Products#555-150006
Black In-Line Fuel Filter
· -10AN
· Gas and Alcohol applications
· 100 micron (stainless) filter
· 5" long x 1-3/4" dia.
All necessary connectors are included. I also found $350 for all this is a steal. ALL WORKS...it's just not for me.
Do you have any pictures of the fuel tank? Used it on E85 (tank)?
Mine decided to disintegrate when I filled it with E85, so I need a new one.
