this may be long....but I need a clear answer.
the issues are
a. my scanmaster
b. my alky kit from razor
now.....if hook either of these up at the fuse box under the dash for a switched power source.....using "add a fuse" gadgets from autozone.....then the whatever car component that runs from that fuse slot is negatively affected by the addition of the "add a fuse" that controls either of the above mentioned aftermarket components.
im thinkin maybe it has something to do with the built in reisistance of the "add a fuse"
but my main question is, where EXACTLY are you guys getting your 12v switched power source for either of the above components?????
thanks
the issues are
a. my scanmaster
thanks
