Just got this car a week or so ago and finally getting into it. Car actually ran well when I picked it up, but was in need of some basic maintenance. It was also showing a code for bad O2. Car is bone stock, even has stock chip. Here is what Ive done:
New O2
Plugs (.35 gap)
Wires
Air Filter
Fuel Filter
Replaced all vacuum lines
Cleaned TB & Iac
Reset ECM
Set Iac & TPS correctly
Car does have a decent header leak (BLM @ 145 at idle) which will be fixed soon.
Here is what the car is doing; it will start and idle nicely but when I give it any throttle it wants to die when it comes back to idle, then rev up quickyl and idle fine again. It doesnt hesitate at all when giving it throttle, just when it comes back to idle.
Did the MAF tap and unplugging it made it run worse actually so guessing thats ok.
Any ideas are appreciated.
New O2
Plugs (.35 gap)
Wires
Air Filter
Fuel Filter
Cleaned TB & Iac
Reset ECM
