Fuel cell sizes
several mfgrs make cells larger than 10 gallons. JAZ, etc all make them.
Watch for warnings on the foam they have available as some foam inserts will melt if it's exposed to alky and other additives.
If you are running gas, I'd recommend the foam option as it keeps the gas slosh down.
Also, be sure to order the following items.
1. Rollover check valve for the vent line. Usually a -6.
2. Check valve to be plumbed in right after the exit from the cell. It keeps the filter and lines and pump full w/ key off.
3. A HIGH flow filter to be installed before the pump and after the check valve.
4. A 90 ohm sender for the gas ga.
Also, remember to read the NHRA rules for installing a cell!!!
The cell HAS to be protected on the bottom and if you put it, [or the fill neck] in the trunk, the entire rear behind the seat HAS to be sealed off, INCLUDING the speaker shelf!!!
Be sure to ground the metal neck of the cell so you won't find the car in "East Peoria" when the static spark ignites the fumes while filling the tank
Back under my fuel cell!!
