streetknight
DCVING
- May 26, 2001
Ok, it's getting frustrating now. I found my code 42 problem to be the Translator + and not DS.
BUT, With the ribbon cable hooked to the ecm the car would "pop" usually just once and nose over, then pick back up. On DS it would show that ALL the readings dropped to Zero. However, it didn't lose power cause the adjutments I had done to Timing and Fuel with the TT chip were still in place.
I have a shielding cable that is zip tied to the ECM and a Wire that is ran from the shielding cable to the firewall of the car to ground it.
I ran the car for 5 passes with no problems and out of the blue the pop was back. It did it 3 times in a row, so I decided to hook up the OTC and unhook the laptop. Made 2 more passes with NO pop without the DS hooked up.
Any ideas?
Any ideas?
