Do my M&A heads need steam holes drilled in them for use on my 4.1 o/c block. I'm sure they do , but wondering why they were not put in by previous owner.
They have 1.94/1.60 valves, so they really don't fit on a 3.8 bore without touching the cylinders. I got them off a stock block motor & saw that every intake valve had touched the wall. I think they have been on 4.1 blocks before & I'm wondering why thier not drilled.
What problems could I run into without them, & to drill them do I just drill straight down from were the gasket lines up to intersect a coolant passage
TIA James
TIA James
