Starter location
Not that much. Two bolts hold it in. You should be able to wrangle it out, but I can't recall if you need to unbolt the downpipe or loosen the crossover to buy a little space. I *think* not. Even so, the crossover pipe is easy access bolts, downpipe is easy too. 1 hour max to remove and replace.
