first turbo
- Dec 13, 2002
C AN ANYONE HELP A ROOKIE AT THIS. SEEMS TO LOAD UP AT IDLE AFTER SITTING THRU A FULL RED LIGHT CAR WILL STALL ON TAKE OFF OR STALL WHILE SITTING THERE. WILL RUN ROUGH AT TAKE OFF AND ALOT OF BLACK SMOKE, WILL SMOOTH OUT AFTER GETTING IN TO THE THROTTLE,OTHER WISE CAR RUNS STRONG.HAVE SCANMASTER NOT REAL SURE ABOUT READINGS 828 AT IDLE JUMPS ALL OVER UNDER LOAD. THANKS.
87gn
009
307 walbor fuel pump
hot wire kit
3" down pipe
ported elbow
flow master
thrasher 93 street chip
adj. fuel reg.
adj. waste gate
scan master
87gn
009
hot wire kit
3" down pipe
ported elbow
flow master
adj. fuel reg.
adj. waste gate
scan master
