Tim Barnum
- Oct 15, 2001
I got my stage 2 motor back and installed in my car. The combo is a 153 on center, stage 2 heads, 230 solid roller cam, stock ecm, 83 lb injectors, T76 turbo, 3" maf with translator and so on. The car runs good with the stock mass air hooked up but it won't run good with the translator and the 3" maf. I've set all of the switches on the translator but it still cuts out under a load. Anyone have a solution? Thanks Tim
