Sputter on warm start ups
Michael30815
Car starts up fine when it cold and drives fine. But whenever I stop at the store after engine is warm, when I crank it back up and drive, it sputter like its flood with gas or something. O2 aren't going above 500"s when warm. Thinking it may be O2 sensor?
It's a possibility the O2 sensor, maybe you can also post the ScanMaster # after engine is warm up.
Cross Counts?
Ok, I have did a lot of change today, first off, I installed my 4 inch MaF today. Also I check the CC perimeter like you ask, it jumps 5 to 12 closed loop all the way to 255. Fuel pressure is set when car is cold at 42 vac off and 40 with the Vac on.
Going to drive tommorow to see if MAF make a difference when starting it back up which it probably won't.
