So I think my Speedo gauge is jacked up. Long sorry short, I was having volt/charging issues a while back . Happen to be a dead volt dash bulb. I had taken the gauge cluster out. Speedo needle had popped out. I thought I had popped it back in. Took car for a drive , it started making noises behind the needle as I accelerated. Then one day, the needle had came off as I was driving . Scanmaster MPH still worked so that’s good but the mileage count was not moving . Went home to put back the needle , same thing, again it popped off.
So I looked into it , looks like the some wire behind the needle is tangled in a mess . I think its suppose to be in a perfect coil right ? it’s a thin hard single wire . But it’s all jacked up .
How can I fix this ?
Thanks fellas
Thanks fellas
