What plugs should I get tonight? I was told to get NGK UR-5s and gap about 32. Anybody want to confirm this is a good direction or have other suggestions. I will set the boost to about 25lbs.
Yea but this is fact: nobody has ECM issues because of resistor core plugs. Period. Why suggest a plug that may lead to issues when there is an alternative that won't. I wish there hadn't been so many people suggesting AR133s on this forum when I went down this road. Would have saved me a month of headaches, swapping back and forth between 2 different chips, 2 different ecms, 3 different power loggers, 2 sets of wires, many many loaded voltage drop tests, etc
At the time I didn't even know they were solid core plugs. I know... Rookie mistake. My aftermarket experience is still growing...
Heat range selection may have a lot to do with it,NGK YR5 or YR6 is a non-projected tip plug and is resistor core.
I ask this sincerely not sarcastically, what is everyone's obsession with solid core racing plugs on everything even stock headed cars? Is it even possible they could gain 1/2 HP?
Do have the stock ignition system? May need to gap tighter than .030", when I was running the stock ignition & alky at 30# I had plugs gapped @ .028". With the TR6 I have them at .033" but haven't turned it up yet
so I should gap at .028- and not .032?
The Racing brand plugs from NGK have a different ceramic construction to help with arc leak from plug boot, Cut back ground strap and non projected tip. Of course the plugs you mentioned could work as well but a EFI and non resistors dont always jive.
