I am looking for solid lifters intended for a flat tappet camshaft (not roller) for the Buick V6. Just for checking valve events and valve to piston clearance.
I am pretty sure that the SBC and Buick lifters are the same diameter - 0.842". Has anyone found that the height of the SBC solid lifters is the same as the Buick hydraulic lifters? Height defined as distance from the lobe contact surface to the pushrod cup.
I assume that SBC lifters are the same height since Schneider sells what are likely SBC lifters with their Buick solid flat tappet camshafts?
http://schneidercams.com/274-84Feven-firesolid.aspx
Thanks for any help. I am open to corrections on what is stated above.
