Hey guys,
In a nutshell here is my problem:
With the Powermaster system on the car (87 GN) my pedal kept going away on me. I tried a new accumulator ball, same thing.
I bought a PM rebuild kit, and rebuilt PM with no problems, but when put back on car, same problem of Pedal going away on me.
Installed a power vacuum system on the car, and still had a pedal that would go away!
We have replaced Prop. Valve, bled the brakes till my leg about fell off, and still same problem. Oh yeah, we also changed Master cylinder at least 3 times now.
I changed out the booster, but evidently I put a bad one on, as the pedal went to a rock hard pedal.
Decided to go with MANUAL MASTER CYLINDER off of an S-10, and modified my pedal and used the "clevice type" adjustable rod out of a '65 Skylark and cut and grinded it to proper length.
(needed to cut and grind tip, but now it's adjustable, almost like what your adjustable wastegate rod is like. It uses a locking nut.)
You may have to do some adjusting etc. to get the rod to press the MC piston properly. Initially the rod was pointed to much skyward when the pedal was pushed, but with modifications, we solved that. Now pushes level with cylinder. Also, consider a "wedge shaped" mounting plate made out of 1/8 inch steel, that way your MC and tank will not be tipped down in the back (firewall side) so much. It takes a little manufacturing, but it sure looks good sitting in there level!
With Manual system, the pedal is better, only goes down about 1/2 way, but I still think something is not right.
We're going to try new calipers, shoes, and cylinders, but if that doesn't fix this issue.....
Anyone have this problem before, and if so, how did you fix it??
All ideas are welcome!
Thanks,
Tim
Thanks,
Tim
