Ok guys,I need some fresh ideas on my trans.First a little history on whats been done to it.Freshened it and installed 12 hours before Noble.Has "red" clutches,billet servo,wider band,.500 boost valve and a Trans-Go shift reprogramming kit(the one that had the option of full manual ).Trans shifts fine at full throttle when manually actuated.Crisp and firm.Little late(400rpm)but further TV adjustment will probly cure that.Problems are at part throttle.When stone cold,sometimes will not downshift to first when coming to a stop.Starts in second(this problem has only happened a couple times and disappears after a couple blocks)when I leave the light.Makes a good shift to drive there after.When at operating temp. trans goes from first,barely "skims" second,and drops into drive early.Lockup is also inconsistent,although can be manually triggered regularly with my lockup switch.Will not lockup in OD on it's own,but sometimes(strangely)will lockup in second then "release" as I speed up and get into higher gears.(when manually triggered lockup holds normally). Could this have something to do with servo seals on the shaft?I know I've written a book here,but since I am in the repair and modification business myself, I know that you can never have enough info on a problem.If you need more,just ask.I hope someone can give me at least a new direction to head as I'm kinda stumped(trans was built by someone else as I watched and asked questions.Never really got into building auto transmissions.Trying to learn them now)
