Brand new high-performance, genuine Siemens Deka, 60lb, 630cc fuel injector. Use for super street or racing applications: This is a Siemens/Deka 4-hole disc-type fuel injector. Injector Body Design: Pencil, Metal and composite plastic. Fuel delivery: 4-hole disc, with filter. Injector type: Siemens/Deka 107961 - Long EV1 electrical connector. Flow rate: 60 lbs/hr, 630 cc/min at 43.5 psi (3 bar). Length: 3 inches, 74 mm. Diameter: 19 mm. O-rings: Top and bottom, 14.5 mm. Resistance: 14 Ohms. Filter basket on top with a four-hole disc fuel delivery nozzle for superior fuel atomization. (All fuel injector specifications meet or exceed the manufacturer's specification standard).
That's the mfgr description of them.. The ECM is not modded in my car.. I just took em out last week, and they work fine. I upgraded to a 6.1 chip and 80's.
