incubus2432
Douchebag
- Jun 23, 2006
I finally got my Metco spare tire well fuel cell installed to feed Razor's kit and have a bug or two to work out. Here are the "symptoms" and pertinent info.....
.....everything worked perfectly prior to the conversion
.....when pushing the test button now the car stumbles as it should but the "armed" light lights red instead of green
.....under boost the armed light never switches to green and I'm getting plenty of alky at 20 psi (I hadn't intended to run 20 psi......guess I turned the adjuster rod a tad too many times)
.....if I disconnect the ground wire from the pump terminal then the green armed light comes on when I press the test button (and it functions as it should). See below for how I wired the ground.
Minor issue....
.....the low fuel light is staying on (plenty of alky in the tank to turn it off). If I manually push the float down the light goes out (reverse of what it should be).
Razor supplied me with the three conductor wiring harness to extend the original to the new pump location and I tested the connections and all is well. The level sender is two wires.....one to the original sender tan wire and one to ground.
The only thing left to me....and I am guessing I am the cause of the problem.....was the mounting of the pump and the wire that connected the bottom/outer most terminal of the pump to the original pump bracket. What I did was mount the pump to the passenger side fuel tank hanger with 4 heavy duty hose clamps (pump fit perfectly in a silicone intercooler coupler) so the pump is isolated from any metal. The terminal that used to be wired to the pump body, and therefore ground, due to original mounting method to the bumper bracket is now wired directly to ground along with the ground wire from the tank level sender. I'm starting to think this is my problem. Should the pump body be directly grounded (I tried just grounding it with a spring clamp and nothing changed)? Would connecting the pump body to the terminal mentioned previously then to ground suffice (seems like the best way to go and close to the original method)? Honestly I'm not even sure of the exact purpose of that terminal.....I just know how it was wired.
I know it sounds like a convoluted mess but I'm sure I'm just missing something simple. I'll call Razor if I must but I've been bugging him plenty lately and just in case I can't get ahold of him on Friday thought I'd post up here as well.
Any thoughts?
Minor issue....
Any thoughts?
