GBGN1
stroked
- May 26, 2001
Bump someone else do this before I do next year!
With parts being available there will me more 3800 cars next year Forsure
for the guys who want to run a stronger trans this is what i buy and get shipped way down here in newzealand to convert the later buick and l67 pattern blocks to T350 400 and glide.have run 11.02 @126mph and the trans is still attached LOL.the plates made from some kind of tool steel or spring steel very solid http://www.speedwaymotors.com/Chevy-4-and-V6-to-TH350-Adapter-Plates,3280.html
Into the 8s now with our jigga. Strong little buggers these L67s.. Still same motor we built back in 2008. Going to keep winding power in till it crys lol.
Any other feedback on the Speedway motors adapter plate? I would like to use the adapter plate to mate up my Built 200-4R to the 3800. Will I be able to keep my multi-disk Precision converter?
I don't want anything to do with a 4L60E since I can't trust them any further than I can throw them and I don't feel like spending 3K to try and make one last behind an engine with power. Using an adapter like the speedway motors one appeals since I can easily install a 4L80E in the future.
Thanks, Dan
I can't offer any info about the adapters but I can tell you that if you are going to use a 2004R with a 3800 Series 2 PCM (as the OP is currently using), that PCM probably won't be able to control the TCC (torque converter clutch) solenoid in a 2004R. So if you use a 3800 engine and PCM with a 2004R in your car, you will need to install some sort of stand-alone TCC solenoid control device if you want the TCC to operate. Such stand alone TCC controllers are sold for the 700R4 transmissions and I have to assume many of those can be made to work on a 2004R with little or no modification (depending on the design of the device).
Tcc on a 200 is easy . You can hydraulically set it up in the trans or just hook up a switch to it. It just needs a 12volt reference.
Hey Dan , long time. Why don't you just pm lonnie and get one of his adapters.
Or just go n/l and not worry about it...
Haha, no worries about me using the factory ECU for the trans. I have a Megasquirt 3x on my GN now which controls the lockup as the original ECU did. There is a bunch of other stuff I have it doing on my GN now which I will move right over to the 3800 including:
-Coil On Plug (LS1 Coils)
-Flex Fuel
-2-Step Launch Control
-Spark Cut rev limiter
-Alky Control
-Boost Control (with over boost protection)
-Closed Loop Speed density
-On the fly tune switching
-On the fly flashing
-Autotune of VE table
-EGT input and protection
-Controls my second fuel pump
It has a lot of other functions it does as well but those are an example of what i have now I don't want to give up for a factory ECU.
Thanks, Dan
Yeah well tx is just to damn hot! So what are you doing ? Building a new car or just want a new set up?
It looks like for the water pump you guys are cutting off the factory outlet and welding it closed, then welding on a port to the line that would usually be designated for the heater lines? Are you all not running a heater anymore? Also for everyone that is running them has this reduced water pump inlet caused any worse cooling?
Thanks, Dan
