The light on the dash and the noise made when you dont have your seatbelt on is not working right in my car. It doesnt matter if the belt is clicked in or not it makes a sad warbling sound and the light flickers, is there a sensor for that?!!?
Yep not a sensor though, it's under the dash it's a black box that chimes. It's either shot or it may be loose in the plug in area. I have the same problem with mine. That box is like 80.00 bucks from some of the vendors. Or if you just want to pull it out you can do that as well, but if you leave your headlights on or key in the ignition it wont ding at you.
