Okay, my car is running fine but I think due to age and oil leaks its time to seal her up. Mileage is 51,000, motor is all original except for the new rear main I put in. Here is my plan, just wondering if anyone can add to my list or offer suggestions:
Pull the motor and replace the following:
Main bearings ( I assume I can get std.?): ~ $40
Rod bearsings ( I assume I can get std.?) ~ $28
Timing Gear set - ~ $22
Timing cover seal: ~ $13
Water Pump: ~ $35
Intake Gasket: ~ $25 - one piece ( Felpro or other?)
oil pan gasket: $15 ( Felpro cork/rubber combo?)
Rear Main seal: ~ $15 ( Felpro here)
Front seal: ~ $17 ( Felpro again)
Valve cover gaskets: ~ $16 ( Felpro 1600s)
Freeze plugs - ~$15
Maybe change following:
Valve Springs ~ $75
Valve Seals ~ $15
Lifters ( Can this be done without replacing the cam?)
Head Gaskets/Bolts ( Should I mess with this given they are not leaking?)
Ideas?
Water Pump: ~ $35
Freeze plugs - ~$15
Valve Springs ~ $75
Valve Seals ~ $15
Ideas?
