Stephen Gibson
Just a participant,Honest
- Mar 3, 2002
Just installed my 2.1 scanmaster and the O2 readings are jumping all over the place even after putting in a new one (oxygen sensor)
and at idle it reads 000 , is this normal or do i have some other problem, The fuel pressure is at 38lbs. and the blm read between 105-150, the tps reads .48 at idle and the iac was 06 and moved a little and integrator reads 128 .The car runs better than it did
but at around 11lbs. boost it started pinging which set off knock
with 93 octane.Any and all help greatly appreciated.
Stephen
P.S.on the sheet for parameters it shows PL (injector pulsewidth)
and SP (spark advance) but mine doesn't show this feature is this optional or just not programmed.
Stephen
