S-400 75mm turbo blowthrough in 79 Cutlass video
quick79
went to Beech Bend on Sat. and did okay. Went 1.48 and 1.51 60' on a 6.12 and a 6.11 pass in the right lane. Swapped lanes and went 1.41 60' but car made a hard right about 100' out and I had to lift. Came back around and got in the left lane again and had a 1.46 60' and went 3.95 to 330' and went 6.03@118.5 and 7.88 to 1000'! Pretty happy with it but wanted a 5 second pass bad! I just had the anti-roll bar installed but still have the Moroso rear springs on the car because my Afco's have not shown up yet. I am impressed with the way the car drives with the anti-roll bar on it and it leaves level. It looks like the car is doing somthing funny to me in the video. Almost looks like it is running out of travel on the front. These passes were made @3410 lbs. with 15lbs. of boost and afr readings between 10.6-11.8. The only video I have is from the 6.11 pass with 1.48 60'. I hope with the new springs on all 4 corners and a shock adjustment this thing will get up and go! A good racetrack would help a bunch too! What do you guys think?
YouTube - 406 SBC TURBO
Sounds like it should easily run a 5.90-80 once you get the suspension sorted and get the 60' in the 1.3x range! Keep up the good work and thanks for the video:cool:
Cool Car!!!!
HOLY BAT SH!TZ...:eek: BAT MAN ...:D. Dude what is your combo. Do you have any pictures. Can you say sleeper? That car is smoking!! I am considering doing a similiar car.
I got a built 400 with about 9:1 compression. Ported Vortec heads. I was considering a ProCharger with a CSU carb on top of a single plane intake Built T400 with a 2800-3000 stall. Any advice would be helpful. Again that car is BADDAZZ:cool:
