Swisher Smirf
- Jun 17, 2012
Hi all need some help. Just had a motor and trans installed at sea level. Got it home 7000 ft in CO and it's running lean under a small amount of boost 15psi. You would think with less oxygen up here it would run fat. I just need advice on what indicator to change 1st. The power logger says the Mid boost is for up to 13-15 psi well I start to lean out at 10. I can't upload the log but here are some pictures. Oh and the car is damn fast it's been a challenge getting WOT logs should I drop the boost down so I can get WOT readings before changing anything on the logger?
