If replacing the MAF and adding a translator is causing your codes according to what you stated in your first post then the issue to look for would start there.3. First thing I did was change the MAF and pipe with Translator. Sine I did that I’m getting codes 33 and 34.
a good deal of use have a 12 volt HotwireInjectors are powered with 12V. The ground side is pulsed by the ecm.
I agree time to put the OE MAS back on and find some good local TURBO Buick help.If replacing the MAF and adding a translator is causing your codes according to what you stated in your first post then the issue to look for would start there.
Did it run OK before you replaced the MAF and translator ?
Are you sure its a 3.5" and not an LT1 3" or an 85mm ?
Did you orient the MAF in the correct direction of air flow. There's an arrow on the MAF pointing the true direction of flow.
If you installed a new chip at the same time you put in the MAF as previously stated above... check for bent pins on the chip.
"Quoting TT Eric" Also, check the ECM chip socket for any pins that are bent in too far, possibly making poor contact with the chip. The ECM socket pins can be carefully bent back out with a pin or needle.
Where in Canada are you located?I wish I had help. Not many that I know of in my area of Canada.
It would be in the harness , it plugs in behind the coil with a big gray plug look thereSo what could cause low voltage to the injector? I do have access to another ecm.
I'm in Eastern Ontario.Eastern Ontario
1 hour and 45 minutes west of you straight down the 401. My engine builder is in Montreal and my transmission builder is from parts unknown. Both are on here...and both keep a low profile...but are the best in Canada.Brockville?
Replaced, now runs worse. Sounds like running on 2 cylinder. Going to try ecm next.It would be in the harness , it plugs in behind the coil with a big gray plug look there
Because you have it plugged in wrong??Replaced, now runs worse. Sounds like running on 2 cylinder. Going to try ecm next.
