Roller rocker adjustment?
slickj52003
Adjusted the roller rocker / cam / lifter set up on car and now running rich and doesn't sound right ( comp cam, comp lifters / harland sharp rockers) I stand bewilder now. I adjusted them the first time and she sounded good but every time I checked the adjustment it seemed as if the rocker would loosen up so I ran through the adjustments again ( up/down rocker wiggle, and spinning the push rod. I'm at wit's end tonight. Anyone running this set up and if so what is your experience? Thanks.
